VW Recolhe 170 mil TDI
Vovin Tharos
Veículos: Golf MK3 GT
Mensagem por Vovin Tharos »
ora vamos assustar meio mundo dos donos de MK6... lol
retirado do vwvortex, portanto pode ser somente para o mercado americano... uma rapida pesquisa pelo google nao encontrei nada sobre o assunto:
Those that have purchased a TDI Golf, Jetta, or SprotWagen for their practicality may have their plans unravel today, as Volkswagen has announced a voluntary recall for those models, in addition to Audi's A3 TDI. The recall effects Golfs made from May 2009 through September 2011, Jettas and Jetta SportWagens made from May 2008 through September 2011, and Audi A3s made from September 2009 through September 2011 sporting a TDI engine under the hood. All in all, close to 170,000 cars are thought to be affected.
At the heart of the recall is the injector line leading to the second injector. It was discovered that the injection pulse's frequency is very similar to the natural frequency of the injector line. This causes extra stress on the line, possibly causing it to crack, and allow fuel to leak out. We all know what happens when fuel leaks out that close to an ignition source. Don't run to your dealer just yet, though, as work doesn't get started until November. Not sure if your car is affected? Keep an eye on your mail, because VW will notify you if they think you're in danger.
em portugues
Aqueles que tenham adquirido um Golf TDI, Jetta, ou SprotWagen por sua praticabilidade podem ter os seus planos complicarem, como a Volkswagen anunciou uma recolha voluntária para esses modelos, além de A3 TDI da Audi. Os efeitos da recolha são para Golfs feitos a partir de maio 2009 até Setembro de 2011, Jettas e SportWagens feita a partir de maio 2008 até Setembro de 2011, e Audi A3s feitas a partir de Setembro de 2009 a Setembro 2011 que ostentem um motor TDI sob o capô. Ao todo, cerca de 170 mil carros são pensados ​​para ser afectados.
No cerne na recolha está a linha de injector que segue para o segundo injector. Foi descoberto que a frequência do pulso de injecção é muito similar à frequência natural da linha do injector. Isso faz com que um esforço extra na linha, podendo causar uma quebra, e permitir que o combustível vaze. Todos nós sabemos o que acontece quando existem fugas de combustível que perto de uma fonte de ignição. Não corra para o seu concessionário, pois, a recolha so começará a ser feita apartir de Novembro. Não tem certeza se seu carro é afectado? Fique de olho no seu e-mail, porque VW irá notificá-lo se o seu veiculo estiver em perigo.
Imagem Imagem
joao_silva
Veículos: vw golf MK4 96 kw/ Skoda Octavia 1XX Kw
Re: VW Recolhe 170 mil TDI
Mensagem por joao_silva »
ainda bem que tenho um mk4 8)
DJ_almiscarado
Mensagem por DJ_almiscarado »
Pelo que li, é apenas nos US que vão ser chamados!
Espero que o meu não tenha esses problemas : :cry:
amgraphics
Mensagem por amgraphics »
impressionante.. mas ainda bem que mesmo após a fabricação analisam os carros. contudo, muito ficaram chocados ao ler este texto.
agora, qual é a motrização tdi afectada??
...::: G4 TDI SR Line :::...
..::powered by himself::..
Vovin Tharos
eles so teem um motor TDI, o 2.0 de 140cvs
Imagem Imagem
Vovin Tharos
numa outra nota, acho que ja ha algumas reclamaçoes do la do de ca do oceano...
Imagem Imagem
carrizog60
Mensagem por carrizog60 »
mas ca nao fazem recolha lol
Old school ...my way of life
Vovin Tharos
e aparentemente, é tambem nos TDI CR, no 2º injector... ja soude de pelo menos um Passat e um A4.
Imagem Imagem
DJ_almiscarado
O meu é um TDI CR 2.0...
Que queixas deveria ter? lol
Vovin Tharos
nenhumas...
so te queixarias caso o segundo injector queimasse, pois é o problema relatado nas americas...
Imagem Imagem
cdi
Mensagem por cdi »
Se nas americas ja estão a recolher todas as unidades de certeza que na europa ja têm a informação para reparar e renovar garantia ou dar mais tempo a esses componentes se eles se danificarem e forem por culpa de fabrico...
Vovin Tharos
lol
nao tinha tanta certeza assim...
Imagem Imagem
nokia5300
Mensagem por nokia5300 »
ainda bem que nao tenho um
Rodcar
Mensagem por Rodcar »
Estranho estarem a fazer isso apenas na américa, deve ser por causo do clima que o injector se queixa... :lol:
De qualquer das maneiras ainda bem que tenho um AFN! :D
jonhyrs
Veículos: jetta 2.0tdi
Mensagem por jonhyrs »
Oi, ppl:
Vi o anuncio de problemas de injectores de vw . varios.
Comprei ha pouco tempo 1 jetta de 2008 2.0 tdi.
Gostava me disesses onde poderei inscreve-lo "VW" para no caso de o chamarem para qualquer mudanca eu saber.
Xau, abracos
Jonhyrs
