vag com duvidas
Hugo1985
vag com duvidas
Mensagem por Hugo1985 » 03 Mar 2018, 21:06
boa noite malta aqui esta a minha primeira mensagem
então a minha duvida e sobre eletrónica comprei um cabo vagcom e fiz um teste e o que aparceu foi isto......
Address 01: Engine Labels: 038-906-019-AJM.lbl
Part No: 038 906 019 AN
Component: 1,9l R4 EDC G000SG 1301
Coding: 00002
Shop #: WSC 01236
VCID: 63C263C7F151592620-4B00
3 Faults Found:
19466 - Relay for Fuel Cooling Pump (J445)
P3010 - 35-10 - Open or Short to Ground - Intermittent
19561 - Valve for Intake Manifold Flap (N239)
P3105 - 35-10 - Open or Short to Ground - Intermittent
17931 - Crash Signal from Airbag Controller
P1523 - 35-10 - Implausible Signal - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0103
Coding: 0019458
Shop #: WSC 01317 785 00200
VCID: 2C50C8FB8C0FD65ED1-513C
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 1.0.0
Coding: 01000
Shop #: WSC 01236
VCID: 214E29CFABCD0B3672-5178
2 Faults Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
01274 - Air Flow Flap Positioning Motor (V71)
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 27 AIRBAG VW5 01 0006
Coding: 12855
Shop #: WSC 01317
VCID: 3566ED9F0F459796BE-4B18
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 825 C
Component: A4-KOMBIINSTR. VDO V09
Coding: 05124
Shop #: WSC 11111
VCID: 285834EBC8F7FA7E35-515A
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y3023278
IMMO-IDENTNR: VWZ7Z0Y3023278
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4H Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 01236
VCID: 0400405B141FFE1E79-4B00
Subsystem 1 - Part No: 1J1959801C
Component: 4H Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 4H Tõrsteuerger. BF0002r
3 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
End-------------------------(Elapsed Time: 05:00)--------------------------
Saturday,03,March,2018,18:53:15:01249
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
Mileage: 304240km-189045mi Repair Order:
e algumas das analises duas acho eu aparceu no vag com a vermelho nomeadamente a primeira então as minhas duvidas e posso apagar os erros sem problemas ou tenho de ter cuidado com algo? o carro ta reprogramadose apagar os erros não mexe em nada nsa reprogramação?
ah e verdade e na analise ao kilometros do carro os kilometros que aparecem e muito menos do que o carro tem isto e normal? obrigado a quem ajudar
Veículos: Golf mk4
Vag Com - AJUDA!!!
Mensagem por KxT27 » 15 Jun 2018, 22:23
Boas malta,
Tenho um cabo Vag-Com e não consigo ligar ao VCDS, dá os seguintes erros
:arrow: Porta USB:
:arrow: Porta COM:
Alguém me consegue ajudar?
tsw21
Veículos: golf mk2 gtd
Re: Vag Com - AJUDA!!!
Mensagem por tsw21 » 15 Jun 2018, 22:34
KxT27 Escreveu:
15 Jun 2018, 22:23
Boas malta,
:arrow: Porta USB:
:arrow: Porta COM:
as drives tao instaladas?e para a versao do teu SO de 34bits ou 64bits? Pode ter haver com isso
Veículos: Golf mk4
Mensagem por KxT27 » 15 Jun 2018, 22:40
tsw21 Escreveu:
15 Jun 2018, 22:34
Sim as drives tao instaladas e atualizadas. Tenho 64bits
tsw21
Re: vag com duvidas
Mensagem por tsw21 » 15 Jun 2018, 23:27
E as drives instaladas sao as de 64bits?,ja me aconteceu isso e o cabo ficou inutilizado,mas tenta instalar tudo novamento com net e antivirus desligado,qual a versao so software?
Veículos: Golf mk4
Re: vag com duvidas
Mensagem por KxT27 » 15 Jun 2018, 23:35
Já configurei para a porta COM4 e atualmente ta assim
Veículos: Golf mk4
Re: vag com duvidas
Mensagem por KxT27 » 15 Jun 2018, 23:38
tsw21 Escreveu:
15 Jun 2018, 23:27
tsw21
Re: vag com duvidas
Mensagem por tsw21 » 15 Jun 2018, 23:45
Eu refiro me a versao do software vcds,nas definicoes no vag com mete em usb.ou entao se tiveres um pc de 32bits experimeta instalar nesse pc
Veículos: Golf mk4
Re: vag com duvidas
Mensagem por KxT27 » 15 Jun 2018, 23:56
tsw21 Escreveu:
15 Jun 2018, 23:45
Eu tenho o VCDS 18.2.1 64x
Não tenho como experimentar em 32x :?
Aparece assim:
tsw21
Re: vag com duvidas
Mensagem por tsw21 » 16 Jun 2018, 00:05
Pois entao e melhor mandares essas imagens a pessoa que vendeu o programa para te ajudar,e desinstala as drives desinsala o programa reinicia o pc e volta a intalar tudo de novo,e quando fazes esse teste tens o interace ligado ao carro e fazes o teste?E a luz verde se n estou em erro tem de acnder porque ha comunicacao
Veículos: Golf mk4
Re: vag com duvidas
Mensagem por KxT27 » 16 Jun 2018, 00:09
tsw21 Escreveu:
16 Jun 2018, 00:05
Por acaso ainda nao testei ligado ao carro desde que o "Port Status" aparece OK, mas ei de testar
Obrigado pelas dicas ;)
tsw21
Re: vag com duvidas
Mensagem por tsw21 » 16 Jun 2018, 00:19
Metes a porta com4 porque essa diz status ok e interface not found,se ligares ao carro na ficha de diagnostico com ignicao ligada,vais ver que deve acender a luz verde do interface e depois provavelmente ele vai dizer interface found,so n sei se é no usb ou porta com,mas devias meter no usb porque vai ser essa a ligacao entre pc e carro,o interface vai tar ligado por usb ao pc. Ve isso e depois diz o resultado
tsw21
Re: vag com duvidas
Mensagem por tsw21 » 16 Jun 2018, 00:21
KxT27 Escreveu:
16 Jun 2018, 00:09
tsw21 Escreveu:
16 Jun 2018, 00:05
A port status ok foi depois de instalares os drivers?
Veículos: Golf mk4
Re: vag com duvidas
Mensagem por KxT27 » 16 Jun 2018, 00:24
tsw21 Escreveu:
16 Jun 2018, 00:21
Não, foi depois de configurar nos drivers para a Porta COM4
Tambem experimentei todas as outras portas COM1, 2, e 3. So a 4 é que apareceu "Port Status - OK
tsw21
Re: vag com duvidas
Mensagem por tsw21 » 16 Jun 2018, 00:28
Experimenta ligar no carro e depois diz algo se n der informa o vendedor e a melhor coisa a fazer depois disto tudo
