Boa noite,
Tenho uma passat B6 de 2007 que quando ligo no painel de instrumentos indica ERRO onde indica os kms . Clicar nos 00 ele apaga e fica os kms do carro.
https://www.dropbox.com/s/kjggr17ahbxh8 ... 4.jpg?dl=0
pelo cabo VAG dá-me os seguintes erros não sei o que fazer
https://www.dropbox.com/s/t9lwxx8e395nrbt/Picture1.jpg
https://www.dropbox.com/s/m3tqukaiyn0ute3/Picture2.jpg
PASSAT B6 Erro Painel
- Veículos: Passat 1.9 TDI
Re: PASSAT B6 Erro Painel
Verifica os fusíveis
Desculpa os do interiror do carro? ou ao pé do motor?
Todos apesar que deve ser do interior
Chequei todos e estão todos bons! =(
VCDS
Windows Based VAG/VAS Emulator Running on Windows 8.1 x64 VCDS Version: Release 17.1.3(x64) Data version: 20170203 DS267.2
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Sunday,15,October,2017,16:41:59:39744
VIN: WVWZZZ3CZ7P128479 License Plate:
Mileage: 146780km-91204mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 65 72 76 77
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LR HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9248
Revision: --H06--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 00028 028 00001
VCID: 7AFC29AA35441991A7-802E
No fault code found.
Readiness: 0 0 0 0 0
------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 109 A HW: 3C0 614 109 A
Component: ESP 440 C4 H018 0001
Revision: H018 Serial number: 0775069477
Coding: 0013569
Shop #: WSC 00028 028 00001 VCID: 1C300F32DF3087A115-8048
------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AF HW: 3C0 907 044 AF
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 65C66AD6ACFA86697A-8030
------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004684787
Coding: E1800F0700041A00470A00000F00000000095D435C0001
VCID: 6CD01FF24F10B72125-8038
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 201106 003 0205
Coding: 00046997
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 220708 046 0204
Coding: 00208933
Shop #: WSC 00028
1 Fault Found:
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 154
Mileage: 146583 km
Time Indication: 0
Date: 2017.10.06
Time: 13:11:00
Freeze Frame:
OFF
Voltage: 12.30 V
OFF
ON
OFF OFF OFF
------------------------------------------------------------------------------- Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 19 AIRBAG VW8R 031 2522
Revision: 12031000 Serial number: 003B2P0VSH3Y
Coding: 0012601
VCID: 316ECE86A8B21AC956-8064
Subsystem 1 - Serial number: 6332MSME15610B2EB
Subsystem 2 - Serial number: 6342MSME16143272+
Subsystem 3 - Serial number: 6351HTS6GIESSLP6-
Subsystem 4 - Serial number: 6361HTS6GIES46C7T
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 M HW: 3C0 953 549 M
Component: J0527 0015
Revision: 00006000 Serial number: 3C5953507AG
Coding: 0000111
VCID: 3664FD9A41DC3DF103-8062
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 134085 km Time Indication: 0 Date: 2014.06.27 Time: 00:00:46
------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C071220113
Coding: 3DFD1E04C61002
VCID: 214E3EC6F852AA49C6-8074
------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 T HW: 3C0 959 433 T
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 01001 261 91941
VCID: 3B72ECAE7AFEE099FC-806E
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000037978117
Coding: 0000183
VCID: 3C70EFB27FF0E7A1F5-8068
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.134 H07 1806
VCID: 3460C79257A02FE13D-8060
------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 051 0218
Coding: 01910A0001860E763004941570084FCE705C00
Subsystem 1 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000056678121
Coding: 0000182
VCID: 3D76E2B664EAEEA9C2-8068
------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 E HW: 3C0 907 801 E
Component: EPB VC8HC003 013 0003
Revision: 013
Coding: 0000012
Shop #: WSC 131071 1023 2097151
VCID: 244037D2E740BF61AD-8070
Alguem me consegue ajudar pfv
www.Ross-Tech.com
Dealer/Shop Name:
Self-Diagnosis Log
Coding: 0000071
Coding: 0013569
Coding: 00046997
Shop #: WSC 00028
Coding: 00208933
Shop #: WSC 00028
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 154
Mileage: 146583 km
Time Indication: 0
Date: 2017.10.06
Time: 13:11:00
Freeze Frame:
OFF
Voltage: 12.30 V
OFF
ON
OFF OFF OFF
Coding: 0012601
Coding: 0000111
1 Fault Found:
014 - Defective
1 Fault Found:
014 - Defective
Coding: 0000183
Coding: 0000182
Revision: 013
Coding: 0000012
