Boas.
Hoje deparei-me com o seguinte, a luz de ESP permanece acesa quando ligo a ignição e o carro não liga, ou seja, o motor de arranque fica a trabalhar constantemente mas o motor não inicia.
Tantas foram as tentativas que fiquei sem bateria.
Por sorte e passado umas horas fui tentar e ligou, mas quando o desliguei apareceu outra vez o mesmo erro e não liga.
Após leitura com o vagcom aprece os seguintes erros:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 CB HW: 028 101 190 0
Component: R4 1,9L EDC G000SG 6176
Revision: 12345678 Serial number: VWZ7Z0E1699092
Coding: 0000072
Shop #: WSC 00028 028 00001
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021121
2 Fault Found:
01314 - Engine Control Module
013- Check DTC Memory - Intermittent
004 - No Signal / Communication . Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AF
Component: Clima
Shop #: WSC 00000 000 00000
1 Fault Found:
004 - No Signal/Communication - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008966051
Coding: E5890F860004180A001400001400000000197F074600000C000000000000
Shop #: WSC 05124 000 08193
Part No: 1K1 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 05124
Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 05124
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K091230045
Coding: E9807F16000202000002
Shop #: WSC 00005 261 10284
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Part No: 1K0 920 861 M
Component: IMMO VDD 0814
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.12 1502
3 Faults Found:
Freeze Frame:
Mileage: 7560 km
Temperature: 51.0°C
Voltage: 12.30 V
Voltage: 12.00 V
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Mileage: 7600 km
Raw, Form. N/A: 000 000 000
Raw, Form. N/A: 000 100 105
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Mileage: 7600 km
Temperature: 37.0°C
Voltage: 9.40 V
Voltage: 9.30 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 81D802487F2D8D0D484F06F010
Part No: 1K8 951 605 B
Component: LIN BACKUP HORN H11 9005
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
End ---------------------------------------------------------------------
Luz ESP acesa e carro não liga (resolvido:centralina nova)
- philip3
Última edição por philip3 em 05 jul 2018, 04:34, editado 1 vez no total.
Re: Luz ESP acesa e carro não liga
Como já te disse por pm, tens um fio partido, ou vários, não tens energia = carro não trabalha
Zonas problemáticas, tubo corrogorado que passa por cima do motor de arranque e frente perto das ventoinhas, se estiver ai o problema estás com muita sorte que não terás de abrir a cablagem toda do carro para encontrar onde está partido/encostado ao chassis.
Estou-te a dizer isso com conhecimento de causa.
Vê também as fichas que ficam ao pé se não me falha a memoria do corta fogos e vaso de água(dependendo do motor dpf ou não), quando digo ver é ver, ver, não é olhar, ou seja, desmontar e inspeccionar, medir sinal.
- philip3
Obrigado pela ajuda Mario. Eu já reparei que a quente é que acontece mais, a frio aparentemente liga logo à primeira ou então tive sorte, mas assim que liga a primeira vez, todas as outras não liga ...
- Veículos: Golf V
Já vi um caso um pouco semelhante e era o cabo de massa negativo que estava danificado, o que liga da bateria ao chassis.
- philip3
Já vi todos os cabos pelo menos os que estão á vista e não aparentam estar danificados.. o que mais me intriga é que é somente a quente aliás basta ligar uma vez que a próxima vez que ligar já tenho que dar umas horas até voltar a ligar...
- philip3
Para atualizar a situação, hoje liguei normal de manha não apareceu nenhum erro, depois fiz cerca de 10 quilometros parei para abastecer e ao ligar apareceu o erro novamente, reparei tambem que quando aparece o erro do ESP as ventoinhas de refrigeração ligam, será normal!? esperei cerca de 8 a 10 minutos rodei a chave e o erro do ESP desapareceu ??!?! esperei com a ignição ligada e as ventoinhas não ligaram, mas por curiosidade liguei novamente sem andar e desliguei , voltou a aparecer o erro ESP e as ventoinhas ligam... ou seja, cada vez que ligo e desligo tenho que dar um compaço de tempo para poder ligar, mas sempre que aparece o erro ESP as ventoinhas ligam!
Logo, basicamente não viste nada daquilo que eu disse.
Se continuares assim arriscas-te a problemas mais graves e mesmo queimar uma ecu ou um incêndio, mas isso já é lá contigo.
Não serve de nada ligares o vag-com se depois nem sequer ligas ao que lá diz, assim como não serve de nada olhar para os fios se não medires sinais ou pelo menos inspeccionares tudo.
Quando tive um carro com um problema semelhante a primeira vez para resolver, a saber no que estava a mexer foi quase 3 dias á volta da instalação eléctrica, sendo que tenho alguma experiência, e agora estás na expectativa de olhar para lá e ver o problema, até poderias ter muita sorte, eu pessoalmente não acredito na sorte.
Vais ter de abrir os tubos corrogorados para inspeccionar.
É normal que a quente tenhas sintomas diferentes pois a resistencia eletrica altera com a temperatura assim como a gestão do motor, porém isso é completamente indiferente para o problema.
- philip3
Obrigado Mário. Assim que tiver novidades coloco as aqui.
Da aqui uma vista de olhos, basicamente aquilo que te expliquei, 100% dos carros que apanhei com o mesmo problema, inclusive o da minha empresa, o stress é sempre aí.
http://forums.tdiclub.com/showthread.php?t=357835
Agradece aos gajos de desenharam a instalação elétrica
- Veículos: VW Tiguan
boa info!!!
- Veículos: Golf V GTI Ed. 30
- philip3
Obrigado Mário.
As fotos não ajudam de muito pois vais ter de desmontar tudo na mesma
Foi só para expressar em imagem aquilo que tentei explicar em cima hehehe
- philip3
resultado filnal... o carro vai ter que levar uma centralina nova. Foi para a VW e ao que parece depois de verificarem tudo e mais alguma coisa, é a centralina que esta com problemas.
Vou deixar aqui os sintomas que tinha no caso de alguem estiver interesado:
- Custava a pegar a quente até ao ponto de não ligar, aparecia a luz de ESP no quadrante.
- Mesmo com a mudança para uma bateria nova os sintomas eram os mesmos.
- A frio pegava bem.
O LauAlf é capaz de te safar uma ECU para o teu 1.9 TDI, penso eu. Envia-lhe uma MP a ver se dá.
